# HomeKit Add-on
- Switchable
- Outlet
- Fan
- Thermostat
- Heater / Cooler
- Lock
- Security System
- Garage Door Opener
- Motorized Door
- Motorized Window
- Window Covering/Blinds
- Slat
- Valve
- Faucet / Shower
- Speaker
- SmartSpeaker
- Microphone
- Air Quality Sensor
- Contact Sensor
- Leak Sensor
- Motion Sensor
- Occupancy Sensor
- Smoke Sensor
- Temperature Sensor
- Humidity Sensor
- Light Sensor
- Carbon Dioxide Sensor
- Carbon Monoxide Sensor
- Battery
- Filter Maintenance
- Television
- Irrigation System
# Quick start
install homekit addon via UI
open Home app on your iPhone or iPad
create new home
add accessory
click "Add Anyway"
follow the instruction of the Home app wizard
Add metadata to more items or fine-tune your configuration using further settings
# Global Configuration
You can define HomeKit settings either via mainUI or via $OPENHAB_CONF/services/homekit.cfg.
Other settings, such as using Fahrenheit temperatures and specifying the interface to advertise the HomeKit bridge are also illustrated in the following sample:
org.openhab.homekit:port=9123
org.openhab.homekit:instances=1
org.openhab.homekit:useDummyAccessories=false
Some settings are only visible in UI if the checkbox "Show advanced" is activated.
# Overview of all settings
| networkInterface | IP address or domain name under which the HomeKit bridge can be reached. If no value is configured, the add-on uses the primary IP address configured for openHAB. If unsure, keep it empty | (none) |
| useOHmDNS | mDNS service is used to advertise openHAB as HomeKit bridge in the network so that HomeKit clients can find it. openHAB has already mDNS service running. This option defines whether the mDNS service of openHAB or a separate service should be used. | false |
| blockUserDeletion | Blocks HomeKit user deletion in openHAB and as result unpairing of devices. If you experience an issue with accessories becoming non-responsive after some time, try to enable this setting. You can also enable this setting if your HomeKit setup is done and you will not re-pair ios devices. | false |
| useFahrenheitTemperature | Set to true to use Fahrenheit degrees, or false to use Celsius degrees. Note if an item has a QuantityType as its state, this configuration is ignored and it's always converted properly. | false |
| instances | Defines how many bridges to expose. Necessary if you have more than 149 accessories. Accessories must be assigned to additional instances via metadata. Additional bridges will use incrementing port numbers. | 1 |
| useDummyAccessories | When an accessory is missing, substitute a dummy in its place instead of removing it. See Dummy Accessories. | false |
If the first word of the item name match the room name in Home app, Home app will hide it. E.g. item with the name "Kitchen Light" will be shown in "Kitchen" room as "Light". This is recommended naming convention for HomeKit items and rooms.
# UI based Configuration
select desired item in mainUI
click on "Add Metadata"
click on "Save"
# Textual configuration
The tag can be:
# Complex Multiple Service Accessories
Alternatively, you may want to have a choice of controlling the items individually, OR as a group, from HomeKit.
The following examples defines a single HomeKit accessory with multiple services that the Home app will allow you to control together, or drill down and control individually.
Note that AccessoryGroup doesn't expose any services itself, but allows you to group other services together underneath it.
Also note that when nesting accessories, you cannot use the shorthand of naming only a characteristic, and not its accessory type, since it would be ambiguous if that item belongs to a secondary service, or to the primary service it's nested under.
Group:Switch:OR(ON,OFF) gLight "Light Group" {homekit="AccessoryGroup"}
Switch light1 "Light 1" (gLight) {homekit="Lighting"}
Switch light2 "Light 2" (gLight) {homekit="Lighting"}
You can also group additional accessories directly under another accessory. In this example, HomeKit will show three separate light controls. As this is somewhat confusing that Home will allow controlling all members as a group, and you also have the group as a distinct switch inside the HomeKit accessory, this is not a recommended configuration.
You can also mix and match accessories:
Group gFan {homekit="Fan"}
Switch fan1 "Fan" (gFan) {homekit="Fan.Active"}
Switch fan1_light "Fan Light" (gFan) {homekit="Lighting"}
Another way to build complex accessories is to associate multiple accessory types with the root group, and then define all of the individual characteristics on group members. When using this style, you cannot have multiple instance of the same accessory type.
Group FanWithLight "Fan with Light" {homekit = "Fan,Lighting"}
Switch FanActiveStatus "Fan Active Status" (FanWithLight) {homekit = "Fan.ActiveStatus"}
Number FanRotationSpeed "Fan Rotation Speed" (FanWithLight) {homekit = "Fan.RotationSpeed"}
Switch Light "Light" (FanWithLight) {homekit = "Lighting.OnState"}
or in MainUI:
Finally, you can link one openHAB item to one or more HomeKit accessories, as well:
You can even form complex sensors this way. Just be sure that you fully specify additional characteristics, so that the addon knows which root service to add it to.
Group eBunkAirthings "Bunk Room Airthings Wave Plus" { homekit="AirQualitySensor,TemperatureSensor,HumiditySensor" }
String Bunk_AirQuality "Bunk Room Air Quality" (eBunkAirthings) { homekit="AirQualitySensor.AirQuality" }
Number:Dimensionless Bunk_Humidity "Bunk Room Relative Humidity [%d %%]" (eBunkAirthings) { homekit="HumiditySensor.RelativeHumidity" }
Number:Temperature Bunk_AmbTemp "Bunk Room Temperature [%.1f °F]" (eBunkAirthings) { homekit="TemperatureSensor.CurrentTemperature" }
Number:Dimensionless Bunk_tVOC "Bunk Room tVOC [%d ppb]" (eBunkAirthings) { homekit="AirQualitySensor.VOCDensity" [ maxValue=10000 ] }
A sensor with a battery configured in MainUI:
The Home app uses the first accessory in a group as the icon for the group as a whole.
E.g. an accessory defined as homekit="Fan,Light" will be shown as a fan and an accessory defined as homekit="Light,Fan" will be shown as a light in the Home app.
You can also override the primary service by using adding primary=<type> to the HomeKit metadata configuration:
Group FanWithLight "Fan with Light" {homekit = "Light,Fan" [primary = "Fan"]}
on in MainUI:
Unusual combinations are also possible, e.g. you can combine temperature sensor with blinds and light.
It will be represented by the Home app as follows:
Note that for sensors that aren't interactive, the Home app will show the constituent pieces in the room and home summaries, and you'll only be able to see the combined accessory when viewing the accessories associated with a particular bridge in the home settings:
# Dummy Accessories
OpenHAB is a highly dynamic system, and prone to occasional misconfigurations where items can't be loaded for various reasons, especially if you're using something besides the UI to manage your items.
This is a problem for HomeKit because if the bridge makes a connection, but accessories are missing, then the HomeKit database will simply remove that accessory.
When the accessory does come back (i.e. because you corrected a syntax error in an .items file, or openHAB completes booting), all customization of that accessory will be lost - the room assignment, customized name, custom icon, status/home screen/favorite preferences, etc.
In order to work around this, the HomeKit addon can create dummy accessories for any accessory it has previously published to HomeKit.
To enable this behavior, turn on the useDummyAccessories setting.
OpenHAB will then simply present a non-interactive accessory for any that are missing.
The openHAB log will also contain information whenever a dummy accessory is created.
If the item backing the accessory is later re-created, everything will sync back up and nothing will be lost.
You can also run the console command openhab:homekit listDummyAccessories to see which items are missing.
Apple devices may or may not show "Not Responding" for some or all accessories when there are dummy accessories, since they will no longer be backed by actual items with state.
It's recommended that you resolve this state as soon as possible, since HomeKit may decide your entire bridge is being uncooperative, and remove everything itself.
If you actually meant to remove an item, you will need to purge the dummy items from the database so that they'll disappear from the Home app altogether.
In order to do so, run the console command openhab:homekit pruneDummyAccessories.
Alternatively, disabling, saving, and then re-enabling useDummyAccessories in the addon settings will have the same effect.
# Dimmers
The way HomeKit handles dimmer devices can be different to the actual dimmers' way of working. HomeKit Home app sends following commands/update:
- On brightness change Home app sends "ON" event along with target brightness, e.g. "Brightness = 50%" + "State = ON".
- On "ON" event Home app sends "ON" along with brightness 100%, i.e. "Brightness = 100%" + "State = ON"
- On "OFF" event Home app sends "OFF" without brightness information.
# Color Temperature
Color temperature can be represented various ways in openHAB. Given the base bulb configured like this:
Group gLight "CCT Light" { homekit="Lighting" }
Switch light_switch (gLight) { homekit="Lighting.OnState" }
The color temperature might be configured in any of these ways:
// Number item presumed in mireds
Number light_temp (gLight) { homekit="Lighting.ColorTemperature" }
// Number item explicitly in mireds
Number:Temperature light_temp "Temp [%.0f mired]" { homekit="Lighting.ColorTemperature" }
// Number item explicitly in Kelvin
Number:Temperature light_temp "Temp [%.0f K]" { homekit="Lighting.ColorTemperature" }
// Dimmer item, with allowed range given in mireds
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue=50, maxValue=400 ]}
// Dimmer item, with allowed range given in Kelvin
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K" ]}
// Dimmer item, where 0% represents "warm" instead of "cool" (i.e. if it's backed by a channel
// that's ultimately interpreting the value in Kelvin instead of mireds)
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K", inverted=true ]}
# Television
HomeKit Televisions are represented as a complex accessory with multiple associated services. The base service is a Television. Then you need to add one or more InputSource services to describe the possible inputs. Finally you can add a TelevisionSpeaker to have control of the audio. A minimal example relying on multiple defaults with a single input, and no speaker:
Group gTelevision "Television" { homekit="Television" }
Switch Television_Switch "Power" (gTelevision) { homekit="Television.Active" }
Group gInput1 "Input 1" (gTelevision) { homekit="InputSource" }
Or, you can go nuts, and fill out many of the optional characteristics, to fully customize your TV:
String Television_Name "Name" (gTelevision) { homekit="Television.ConfiguredName" }
Number Television_CurrentInput "Current Input" (gTelevision) { homekit="Television.ActiveIdentifier" }
String Television_RemoteKey "Remote Key" (gTelevision) { homekit="Television.RemoteKey" }
Switch Television_SleepDiscoveryMode "Sleep Discovery Mode" (gTelevision) { homekit="Television.SleepDiscoveryMode" }
Dimmer Television_Brightness "Brightness" (gTelevision) { homekit="Television.Brightness" }
Switch Television_PowerMode "Power Mode" (gTelevision) { homekit="Television.PowerMode" }
Switch Television_ClosedCaptions "Closed Captions" (gTelevision) { homekit="Television.ClosedCaptions" }
String Television_CurrentMediaState "Current Media State" (gTelevision) { homekit="Television.CurrentMediaState" }
String Television_TargetMediaState "Target Media State" (gTelevision) { homekit="Television.TargetMediaState" }
String Television_PictureMode "Picture Mode" (gTelevision) { homekit="Television.PictureMode" }
Switch Input1_Visible "Visibility" (gInput1) { homekit="InputSource.CurrentVisibility" }
Switch Input1_TargetVisibility "Target Visibility" (gInput1) { homekit="InputSource.TargetVisibilityState" }
Group gInput2 "Input 2" (gTelevision) { homekit="InputSource"[Identifier=2, InputDeviceType="AUDIO_SYSTEM", InputSourceType="HDMI"] }
String Input2_Name "Name" (gInput2) { homekit="InputSource.ConfiguredName" }
Switch Input2_Configured "Configured" (gInput2) { homekit="InputSource.Configured" }
Switch Input2_Visible "Visibility" (gInput2) { homekit="InputSource.CurrentVisibility" }
Switch Input2_TargetVisibility "Target Visibility" (gInput2) { homekit="InputSource.TargetVisibilityState" }
Group gTelevisionSpeaker "Speaker" (gTelevision) { homekit="TelevisionSpeaker" }
Switch Television_Mute "Mute" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Mute" }
Switch Television_SpeakerActive "Speaker Active" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Active" }
Dimmer Television_Volume "Volume" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Volume,TelevisionSpeaker.VolumeSelector" }
Note that seemingly most of these characteristics are not accessible from the Home app. At the least, you should be able to edit names, control main power, switch inputs, alter input visibility, and be notified when the user wants to open the TV's menu.
- OPEN if position is 0%,
- CLOSED if position is 100%.
- OPEN if position 100%
- CLOSED if position is 0%
Therefore, HomeKit integration inverts by default the values between openHAB and HomeKit, e.g. if openHAB current position is 30% then it will send 70% to HomeKit app. In case you need to disable this logic you can do it with configuration parameter inverted=false, e.g.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [inverted=false]}
Rollershutter window "Window" {homekit = "Window" [inverted=false]}
Rollershutter door "Door" {homekit = "Door" [inverted=false]}
HomeKit home app never sends "STOP" but only the target position. If you add configuration parameter "stop=true", openHAB will emulate stop and send "STOP" command to rollershutter item if you click on the blind icon in the iOS home app while the blind is moving.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [stop=true]}
Some blinds devices do support "STOP" command but would stop if they receive UP/DOWN while moving om the same direction. In order to support such devices add "stopSameDirection" parameter.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [stop=true, stopSameDirection=true]}
Rollershutter window_covering "Blind" (gBlind) {homekit = "CurrentPosition, TargetPosition, PositionState"}
Dimmer window_covering_htilt "Blind horizontal tilt" (gBlind) {homekit = "CurrentHorizontalTiltAngle, TargetHorizontalTiltAngle"}
Dimmer window_covering_vtilt "Blind vertical tilt" (gBlind) {homekit = "CurrentVerticalTiltAngle, TargetVerticalTiltAngle"}
# Thermostat
- CurrentTemperature
- TargetTemperature
- CurrentHeatingCoolingMode
- TargetHeatingCoolingMode
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit = "CurrentTemperature"}
Number thermostat_target_temp "Thermostat Target Temp [%.1f °C]" (gThermostat) {homekit = "TargetTemperature"}
In addition, thermostat can have thresholds for cooling and heating modes. Example with thresholds:
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit = "TargetTemperature"}
Number thermostat_cool_thrs "Thermostat Cool Threshold Temp [%.1f °C]" (gThermostat) {homekit = "CoolingThresholdTemperature"}
Number thermostat_heat_thrs "Thermostat Heat Threshold Temp [%.1f °C]" (gThermostat) {homekit = "HeatingThresholdTemperature"}
# Min / max temperatures
- current temperature: min value = 0 °C, max value = 100 °C
- target temperature: min value = 10 °C, max value = 38 °C
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit = "CurrentTemperature" [minValue=5, maxValue=30]}
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit = "TargetTemperature" [minValue=10.5, maxValue=27]}
# Thermostat modes
These modes are mapped to string values of openHAB items using configuration at the item level. e.g. if your current mode item can have following values: "OFF", "HEATING", "COOLING" then you need following mapping at item level
You can provide mapping for target mode in a similar way.
The custom mapping can be also used to reduce number of modes shown in Home app. The modes can be only reduced, but not added, i.e. it is not possible to add a new custom mode to HomeKit thermostat.
# Valve
Upon valve activation in Home app, Home app starts to count down from the "duration" to "0" without contacting the server. Home app also does not trigger any action if it remaining duration get 0. It is up to valve to have an own timer and stop valve once the timer is over. Some valves have such timer, e.g. pretty common for sprinklers. In case the valve has no timer capability, openHAB can take care on this - start an internal timer and send "Off" command to the valve once the timer is over.
- valve with timer:
Group gValve "Valve Group" {homekit="Valve" [ValveType="Irrigation"]}
Group gValve "Valve Group" {homekit="Valve" [ValveType="Irrigation", homekitTimer="true"]}
# Irrigation System
An irrigation system is an accessory composed of multiple valves. You just need to link multiple valves within an irrigation system's group. When part of an irrigation system, valves are required to have Duration and RemainingDuration characteristics, as well as a ServiceIndex. The valve's types will also automatically be set to IRRIGATION.
Group gIrrigationSystem "Irrigation System" { homekit="IrrigationSystem" }
String irrigationSystemProgramMode (gIrrigationSystem) { homekit="ProgramMode" }
Switch irrigationSystemEnabled (gIrrigationSystem) { homekit="Active" }
Switch irrigationSystemInUse (gIrrigationSystem) { homekit="InUseStatus" }
Group irrigationSystemTotalRemaining (gIrrigationSystem) { homekit="RemainingDuration" }
Group gValve1 "Valve 1" (gIrrigationSystem) { homekit="Valve"[ServiceIndex=1] }
Switch valve1Active (gValve1) { homekit="ActiveStatus" }
Switch valve1InUse (gValve1) { homekit="InUseStatus" }
Number valve1SetDuration (gValve1) { homekit="Duration" }
Number valve1RemainingDuration (gValve1) { homekit="RemainingDuration" }
Group gValve2 "Valve 2" (gIrrigationSystem) { homekit="Valve"[ServiceIndex=2] }
Switch valve2Active (gValve2) { homekit="ActiveStatus" }
Switch valve2InUse (gValve2) { homekit="InUseStatus" }
Number valve2SetDuration (gValve2) { homekit="Duration" }
Number valve2RemainingDuration (gValve2) { homekit="RemainingDuration" }
# Sensors
| BatteryLowStatus | Switch, Contact, Number | Accessory battery status. "ON"/"OPEN" indicates that the battery level of the accessory is low. Value should return to "OFF"/"CLOSED" when the battery charges to a level that's above the low threshold. Alternatively, you can give a Number item that's the battery level, and if it's lower than the lowThreshold configuration, it will report low. |
Switch and Contact items support inversion of the state mapping, e.g. by default the openHAB switch state "ON" is mapped to HomeKit contact sensor state "Open", and "OFF" to "Closed". The configuration "inverted=true" inverts this mapping, so that "ON" will be mapped to "Closed" and "OFF" to "Open".
Number temperature_sensor "Temperature Sensor [%.1f °C]" {homekit="TemperatureSensor"}
Contact contact_sensor "Contact Sensor" {homekit="ContactSensor" [inverted=true]}
Switch leaksensor_active "Leak Sensor Active" (gLeakSensor) {homekit="ActiveStatus" [inverted=true]}
Switch motionsensor_bat "Motion Sensor Battery" (gMotionSensor) {homekit="BatteryLowStatus" [inverted=true]}
or using UI
# Supported accessory types
For configuration options, the default values are in parentheses.
For enum values, the parentheses indicate the default values if the item is a Number or a Switch.
All enum values can be customized via item metadata. I.e. HEAT="heating", COOL="cooling", or HEAT=5, COOL=7 for a Number.
Some enums can have the list of valid values customized, meaning that if you customize the mapping, any value that is missing will not be presented to the user.
They are appropriately marked.
Enums that are linked to Switches or Contacts have an inverted param that will reverse the sense of ON/OFF or OPEN/CLOSED.
| Accessory Tag | Mandatory Characteristics | Optional Characteristics | Supported openHAB item types | Description | Configuration Options | Valid Enum Values |
| AirQualitySensor | Air Quality Sensor which can measure different parameters | |||||
| AirQuality | Number, String, Switch | Air quality state | UNKNOWN (0, OFF), EXCELLENT (1, ON), GOOD (2), FAIR (3), INFERIOR (4), POOR (5) | |||
| ActiveStatus | Contact, Switch | Working status | ||||
| BatteryLowStatus | Contact, Number, Switch | Battery status | inverted (false), lowThreshold (20) | |||
| FaultStatus | Contact, Number, String, Switch | Fault status | inverted (false) | NO_FAULT (0, OFF, CLOSED), GENERAL_FAULT (1, ON, OPEN) | ||
| Name | String | Name of the sensor | ||||
| NitrogenDioxideDensity | Number | NO2 density in micrograms/m3, max 1000 | ||||
| OzoneDensity | Number | Ozone density in micrograms/m3, max 1000 | ||||
| PM10Density | Number | PM10 micrometer particulate density in micrograms/m3, max 1000 | ||||
| PM25Density | Number | PM2.5 micrometer particulate density in micrograms/m3, max 1000 | ||||
| SulphurDioxideDensity | Number | SO2 density in micrograms/m3, max 1000 | ||||
| TamperedStatus | Contact, Number, String, Switch | Tampered status | inverted (false) | NOT_TAMPERED (0, OFF, CLOSED), TAMPERED (1, ON, OPEN) | ||
| VOCDensity | Number | VOC Density in micrograms/m3, default max 1000 | minValue (0), maxValue (100), step (1) | |||
| BasicFan | Fan. A BasicFan is a subset of Fan, but the Home app allows you to customize the icon of the accessory to show a ceiling fan. | |||||
| OnState | Dimmer, Switch | Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. | inverted (false) | |||
| RotationDirection | Number, Switch | Rotation direction. | inverted (false) | CLOCKWISE (0, OFF), COUNTER_CLOCKWISE (1, ON) | ||
| RotationSpeed | Dimmer, Number | Fan rotation speed in % (1-100) | ||||
| Battery | Accessory with battery. Battery can be chargeable (configuration chargeable:true) and non-chargeable (configuration chargeable:false) | |||||
| BatteryLevel | Number | Battery level 0% to 100% | ||||
| BatteryChargingState | Contact, Dimmer, Switch | Mandatory only for chargeable battery. ON/OPEN = battery is charging | ||||
| BatteryLowStatus | Contact, Number, Switch | Battery low indicator. ON/OPEN = battery level is low; for number if the value is below the lowThreshold, then it is low. Default is 20. | inverted (false), lowThreshold (20) | |||
| Name | String | Name of the battery accessory | ||||
| CarbonDioxideSensor | Carbon Dioxide Sensor | |||||
| CarbonDioxideDetectedState | Contact, Dimmer, Switch, Number, String | carbon dioxide sensor state | inverted (false) | NORMAL (0, OFF, CLOSED), ABNORMAL (1, ON, OPEN) | ||
| CarbonDioxideLevel | Number | Carbon dioxide level in ppm, max 100000 | ||||
| CarbonDioxidePeakLevel | Number | highest detected level (ppm) of carbon dioxide detected by a sensor, max 100000 | ||||
| CarbonMonoxideSensor | Carbon monoxide Sensor | |||||
| CarbonMonoxideDetectedState | Contact, Dimmer, Switch, Number, String | Carbon monoxide sensor state | inverted (false) | NORMAL (0, OFF, CLOSED), ABNORMAL (1, ON, OPEN) | ||
| CarbonMonoxideLevel | Number | Carbon monoxide level in ppm, max 100 | ||||
| CarbonMonoxidePeakLevel | Number | highest detected level (ppm) of carbon monoxide detected by a sensor, max 100 | ||||
| ContactSensor | Contact Sensor, An accessory with on/off state that can be viewed in HomeKit but not changed such as a contact sensor for a door or window | |||||
| ContactSensorState | Contact, Dimmer, Number, String, Switch | Contact sensor state | inverted (false) | DETECTED (0, OFF, CLOSED), NOT_DETECTED (1, ON, OPEN) | ||
| Door | Motorized door. One Rollershutter item covers all mandatory characteristics. see examples below. | |||||
| CurrentPosition | Dimmer, Number, Rollershutter | Current position of motorized door | ||||
| PositionState | Number, Rollershutter, String | Position state. If no state is provided, "STOPPED" is used. | DECREASING (0), INCREASING (1), STOPPED (2) | |||
| TargetPosition | Dimmer, Number, Rollershutter | Target position of motorized door | ||||
| HoldPosition | Rollershutter, Switch | Motorized door should stop at its current position. ON is sent to Switch items. STOP is sent to Rollershutter items. Only supported by 3rd party Home apps (such as Elgato Eve) | ||||
| Name | String | Name of the motorized door | ||||
| ObstructionStatus | Contact, Dimmer, Switch | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | ||||
| Fan | Fan | |||||
| ActiveStatus | Dimmer, Switch | Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. | ||||
| CurrentFanState | Number, String | Current fan state. | INACTIVE (0), IDLE (1), BLOWING_AIR (2) | |||
| LockControl | Number, Switch, String | Status of physical control lock | inverted (false) | CONTROL_LOCK_DISABLED (0, OFF), CONTROL_LOCK_ENABLED (1, ON) | ||
| RotationDirection | Number, Switch, String | Rotation direction | inverted (false) | CLOCKWISE (0, OFF), COUNTER_CLOCKWISE (1, ON) | ||
| SwingMode | Number, Switch, String | Swing mode | inverted (false) | SWING_DISABLED (0, OFF), SWING_ENABLED (1, ON) | ||
| TargetFanState | Number, Switch, String | Target fan state | inverted (false) | MANUAL (0, OFF), AUTO (1, ON) | ||
| Faucet | Faucet or shower. It should be used in combination with Valve or/and HeaterCooler. | |||||
| Active | Contact, Dimmer, Switch | Accessory current working status | inverted (false) | |||
| Name | String | Name of the Faucet | ||||
| Filter | Accessory with filter maintenance indicator | |||||
| FilterChangeIndication | Contact, Dimmer, Number, String, Switch | Filter change indicator | inverted (false) | NO_CHANGED_NEEDED (0, OFF, CLOSED), CHANGE_NEEDED (1, ON, OPEN) | ||
| FilterLifeLevel | Number | Current filter life level. 0% to 100% | ||||
| FilterResetIndication | Switch | Send "filter reset" action triggered by user in iOS Home app to openHAB ("ON" = reset requested by user). | ||||
| Name | String | Name of the filter accessory | ||||
| GarageDoorOpener | A garage door opener. | |||||
| CurrentDoorState | Contact, Switch, Number, String | Current door state. | inverted (false) | OPEN (0, ON, OPEN), CLOSED (1, OFF, CLOSED), OPENING (2), CLOSING (3), STOPPED (4) | ||
| ObstructionStatus | Contact, Switch | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | inverted (false) | |||
| TargetDoorState | Contact, Switch, Number, String | Target door state. | inverted (false) | OPEN (0, ON, OPEN), CLOSED (1, OFF, CLOSED) | ||
| Name | String | Name of the garage door | ||||
| HeaterCooler | Heater or/and cooler device | |||||
| CurrentHeaterCoolerState | Number, String | Current heater/cooler mode. | INACTIVE (0), IDLE (1), HEATING (2), COOLING (3) | |||
| CurrentTemperature | Number | Current temperature | minValue (0), maxValue (100), step (0.1) | |||
| TargetHeaterCoolerState | Number, String | Target heater/cooler mode. | AUTO (0, OFF), HEAT (1, ON), COOL (2) * | |||
| CoolingThresholdTemperature | Number | Maximum temperature that must be reached before cooling is turned on | minValue (10), maxValue (35), step (0.1) | |||
| HeatingThresholdTemperature | Number | Minimum temperature that must be reached before heating is turned on | minValue (0), maxValue (25), step (0.1) | |||
| Name | String | Name of the heater/cooler | ||||
| RotationSpeed | Number | Fan rotation speed in % (1-100) | ||||
| HumiditySensor | Relative Humidity Sensor providing read-only values | |||||
| RelativeHumidity | Number | Relative humidity in % between 0 and 100 | homekitMultiplicator = {number to multiply result with} | |||
| InputSource | Input source linked service. Can only be used with Television. | |||||
| Name | String | Default name of the input source | ||||
| ConfiguredName | String | Name of the input source configured in the iOS Home app. User can rename the source in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app. | ||||
| Configured | Contact, Dimmer, Switch | If the source is configured on the device. Non-configured inputs will not show up in the Home app. - ON/OPEN = show, OFF/CLOSED = hide. Default is ON. Can also be configured via metadata, e.g. [Configured=true] | ||||
| CurrentVisibility | Contact, Dimmer, Number, String, Switch | If the source has been hidden by the user. Can also be configured via metadata, e.g. [CurrentVisibility=false] | inverted (false) | SHOWN (0, ON), HIDDEN (1, OFF) | ||
| Identifier | Number | The identifier of the source, to be used with the ActiveIdentifier characteristic. Can also be configured via metadata, e.g. [Identifier=1] | ||||
| InputDeviceType | String | Type of the input device. possible values (OTHER, TV, RECORDING, TUNER, PLAYBACK, AUDIO_SYSTEM). Custom mapping can be defined at item level. Can also be configured via metadata, e.g. [InputDeviceType="OTHER"]. | ||||
| InputSourceType | String | Type of the input source. possible values (OTHER, HOME_SCREEN, TUNER, HDMI, COMPOSITE_VIDEO, S_VIDEO, COMPONENT_VIDEO, DVI, AIRPLAY, USB, APPLICATION). Custom mapping can be defined at item level. Can also be configured via metadata, e.g. [InputSourceType="OTHER"]. | ||||
| TargetVisibilityState | Switch, Number, String | The desired visibility state of the input source. | inverted (false) | SHOWN (0, ON), HIDDEN (1, OFF) | ||
| IrrigationSystem | An accessory that represents multiple water valves and accommodates a programmed scheduled. | |||||
| Active | Contact, Dimmer, Number, String, Switch | If the irrigation system as a whole is enabled. This must be ON if any of the valves are also enabled. | inverted (false) | INACTIVE (0, OFF), ACTIVE (1, ON) | ||
| InUseStatus | Contact, Dimmer, Number, String, Switch | If the irrigation system as a whole is running. This must be ON if any of the valves are ON. | inverted (false) | NOT_IN_USE (0, OFF, CLOSED), IN_USE (1, ON, OPEN) | ||
| ProgramMode | String | The current program mode of the irrigation system. Possible values (NO_SCHEDULED - no programs scheduled, SCHEDULED - program scheduled, SCHEDULED_MANUAL - program scheduled, currently overriden to manual mode). | ||||
| RemainingDuration | Number | The remaining duration for all scheduled valves in the current program in seconds. | ||||
| LeakSensor | Leak Sensor | |||||
| LeakDetectedState | Contact, Dimmer, Number, String, Switch | Leak sensor state | inverted (false) | LEAK_NOT_DETECTED (0, OFF, CLOSED), LEAK_DETECTED (1, ON, OPEN) | ||
| LightSensor | Light sensor | |||||
| LightLevel | Number | Light level in lux | minValue (0.0001), maxValue (100000) | |||
| Lighting | A lightbulb, can have further optional parameters for brightness, hue, etc | |||||
| OnState | Switch | State of the light - ON/OFF | ||||
| Brightness | Dimmer, Color | Brightness in % (1-100). See "Usage of dimmer modes" for configuration details. | ||||
| ColorTemperature | Dimmer, Number | Color temperature. If the item is a Number with no units, it is represented in mireds. The default value range is from 50 to 400 (2500 K to 20,000 K). If the item is a Dimmer, it will be transformed linearly to mireds. Color temperature should not be used in combination with hue, saturation and brightness. | minValue (50), maxValue (400), inverted | |||
| Hue | Dimmer, Color | Hue | ||||
| Name | String | Name of the light | ||||
| Saturation | Dimmer, Color | Saturation in % (1-100) | ||||
| Lock | A Lock Mechanism | inverted (false) | ||||
| LockCurrentState | Contact, Number, String, Switch | Current state of lock mechanism | inverted (false) | UNSECURED (0, OFF, CLOSED), SECURED (1, ON, OPEN), JAMMED (2), UNKNOWN (3) | ||
| LockTargetState | Number, String, Switch | Target state of lock mechanism | inverted (false) | UNSECURED (0, OFF), SECURED (1, ON) | ||
| Name | String | Name of the lock | ||||
| Microphone | Microphone accessory | |||||
| Mute | Contact, Dimmer, Switch | Mute indication. ON/OPEN = microphone is muted | inverted (false) | |||
| Name | String | Name of the microphone accessory | ||||
| Volume | Number | Microphone volume from 0% to 100% | ||||
| MotionSensor | Motion Sensor | |||||
| MotionDetectedState | Contact, Dimmer, Switch | Motion sensor state (ON=motion detected, OFF=no motion) | inverted (false) | |||
| OccupancySensor | Occupancy Sensor | |||||
| OccupancyDetectedState | Contact, Dimmer, Number, String, Switch | Occupancy sensor state | inverted (false) | NOT_DETECTED (0, OFF, CLOSED), DETECTED (1, ON, OPEN) | ||
| Outlet | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||||
| InUseStatus | Contact, Dimmer, Switch | Indicates whether the outlet has an appliance e.g., a floor lamp, physically plugged in. This characteristic is set to True even if the plugged-in appliance is off. | inverted (false) | |||
| OnState | Dimmer, Switch | State of the outlet - ON/OFF | ||||
| Name | String | Name of the switch | ||||
| SecuritySystem | Security system. | |||||
| CurrentSecuritySystemState | Number, String | Current state of the security system | STAY_ARM (0), AWAY_ARM (1), NIGHT_ARM (2), DISARMED (3), TRIGGERED (4) | |||
| TargetSecuritySystemState | Number, String | Requested state of the security system. While the requested state is not DISARM, and the current state is DISARMED, HomeKit will display "Arming...", for example during an exit delay. | STAY_ARM (0), AWAY_ARM (1), NIGHT_ARM (2), DISARM (3) * | |||
| Name | String | Name of the security system | ||||
| Slat | Slat which tilts on a vertical or a horizontal axis. Configuration "type:horizontal" or "type:vertical" | |||||
| CurrentSlatState | Number, String | Current slat state. | FIXED (0), JAMMED (1), SWINGING (2) | |||
| CurrentTiltAngle | Dimmer, Number | Number Item = current angle of slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. Dimmer Item = the percentage of openness (0%-100%) | ||||
| Name | String | Name of the slat | ||||
| TargetTiltAngle | Dimmer, Number | Number Item = target angle of slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%) | ||||
| SmartSpeaker | Smart speaker accessory with Play/Stop/Pause control | |||||
| CurrentMediaState | Number, String | Current smart speaker state | PLAY (0), PAUSE (1), STOP (2), UNKNOWN (3) | |||
| TargetMediaState | Number, String | Target smart speaker state | PLAY (0), PAUSE (1), STOP (2) | |||
| ConfiguredName | String | Name of the speaker accessory configured in iOS Home app. User can rename the speaker in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app. | ||||
| Mute | Contact, Switch | Mute indication. ON/OPEN = speaker is muted | inverted (false) | |||
| Name | String | Name of the speaker accessory | ||||
| Volume | Number | Speaker volume from 0% to 100% | ||||
| SmokeSensor | Smoke Sensor | |||||
| SmokeDetectedState | Contact, Dimmer, Number, String, Switch | Smoke sensor state | inverted (false) | NOT_DETECTED (0, OFF, CLOSED), DETECTED (1, ON, OPEN) | ||
| Speaker | Speaker accessory | |||||
| Mute | Contact, Dimmer, Switch | Mute indication. ON/OPEN = speaker is muted | inverted (false) | |||
| Active | Contact, Dimmer, Number, String, Switch | Accessory current working status | inverted (false) | INACTIVE (0, OFF), ACTIVE (1, ON) | ||
| Switchable | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||||
| OnState | Dimmer, Switch | State of the switch - ON/OFF | ||||
| Television | Television accessory with inputs | |||||
| Active | Contact, Dimmer, Number, String, Switch | State of the television (on/off) | inverted (false) | INACTIVE (0, OFF), ACTIVE (1, ON) | ||
| ActiveIdentifier | Number | The input that is currently active (based on its identifier). Can also be configured via metadata, e.g. [ActiveIdentifier=1] | ||||
| Brightness | Dimmer | Screen brightness in % (1-100). | ||||
| ClosedCaptions | Contact, Dimmer, Number, String, Switch | Indicates closed captions are enabled. Can also be configured via metadata, e.g. [ClosedCaptions=true] | inverted (false) | DISABLED (0, OFF), ENABLED (1, ON) | ||
| ConfiguredName | String | Name of the television accessory configured in the iOS Home app. User can rename the television in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app. | ||||
| CurrentMediaState | Number, String | Current television state. | PLAY (0), PAUSE (1), STOP (2), UNKNOWN (3) | |||
| Name | String | Name of the television accessory | ||||
| PictureMode | Number, String | Selected picture mode. | OTHER (0), STANDARD (1), CALIBRATED (2), CALIBRATED_DARK (3), VIVID (4), GAME (5), COMPUTER (6), CUSTOM (7) | |||
| PowerMode | Switch, Number, String | This oddly named characteristic will receive an ON command when the user requests to open the TV's menu. | inverted (false) | SHOW (0, ON), HIDE (1, OFF) | ||
| RemoteKey | String | Receives a keypress event. | ||||
| SleepDiscoveryMode | Contact, Dimmer, Number, String, Switch | Indicates if the television is discoverable while in standby mode. Can also be configured via metadata, e.g. [SleepDiscoveryMode=true] | inverted (false) | NOT_DISCOVERABLE (0, OFF), ALWAYS_DISCOVERABLE (1, ON) | ||
| TargetMediaState | Number, String | Target television state. | PLAY (0), PAUSE (1), STOP (2) | |||
| TelevisionSpeaker | An accessory that can be added to a Television in order to control the speaker associated with it. | |||||
| Mute | Switch | If the television is muted. ON = muted, OFF = not muted. | ||||
| Active | Contact, Dimmer, Number, String, Switch | Unknown. This characteristic is undocumented by Apple, but is still available. | inverted (false) | INACTIVE (0, OFF), ACTIVE (1, ON) | ||
| Volume | Dimmer, Number | Current volume. | ||||
| VolumeControlType | String | The type of control available. This will default to infer based on what other items are linked. NONE = status only, no control; RELATIVE = INCREMENT/DECREMENT only, no status; RELATIVE_WITH_CURRENT = INCREMENT/DECREMENT only with status; ABSOLUTE = direct status and control. Can also be configured via metadata, e.g. [VolumeControlType="ABSOLUTE"]. | ||||
| VolumeSelector | Dimmer, String | If linked to a dimmer item, will send INCREASE/DECREASE commands. If linked to a string item, will send INCREMENT and DECREMENT. | ||||
| TemperatureSensor | Temperature sensor | |||||
| CurrentTemperature | Number | current temperature | minValue (0), maxValue (100), step (0.1) | |||
| Thermostat | A thermostat requires all mandatory characteristics defined below | |||||
| CurrentHeatingCoolingMode | Number, String | Current heating cooling mode | OFF (0, OFF), HEAT (1, ON), COOL (2) | |||
| CurrentTemperature | Number | Current temperature. | minValue (0), maxValue (100), step (0.1) | |||
| TargetHeatingCoolingMode | Number, String | Target heating cooling mode | OFF (0, OFF), HEAT (1, ON), COOL (2), AUTO (3) * | |||
| TargetTemperature | Number | Target temperature. | minValue (10), maxValue (38), step (0.1) | |||
| Name | String | Name of the thermostat | ||||
| RelativeHumidity | Number | Relative humidity in % between 0 and 100. | ||||
| Valve | Valve | ValveType = ["Generic", "Irrigation", "Shower", "Faucet"] ("Generic") | ||||
| InUseStatus | Contact, Dimmer, Switch | Indicates whether fluid flowing through the valve. A value of "ON"/"OPEN" indicates that fluid is flowing. | inverted (false) | |||
| Duration | Number | Defines how long a valve should be set to ʼIn Useʼ in second. | homekitDefaultDuration = {default duration in seconds} | |||
| Name | String | Name of the valve | ||||
| RemainingDuration | Number | Describes the remaining duration on the accessory. the remaining duration increases/decreases from the accessoryʼs usual countdown. i.e. changes from 90 to 80 in a second. | ||||
| Window | Motorized window. One Rollershutter item covers all mandatory characteristics. see examples below. | |||||
| CurrentPosition | Dimmer, Number, Rollershutter | Current position of motorized window | ||||
| TargetPosition | Dimmer, Number, Rollershutter | Target position of motorized window | ||||
| Name | String | Name of the motorized window | ||||
| WindowCovering | Window covering / blinds. One Rollershutter item covers all mandatory characteristics. see examples below. | |||||
| CurrentPosition | Dimmer, Number, Rollershutter | Current position of window covering | ||||
| TargetPosition | Dimmer, Number, Rollershutter | Target position of window covering | ||||
| CurrentHorizontalTiltAngle | Dimmer, Number | Number Item = current angle of horizontal slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. A value of -90 indicates that the slats are rotated all the way in a direction where the user-facing edge is higher than the window-facing edge. Dimmer Item = the percentage of openness (0%-100%) | ||||
| CurrentVerticalTiltAngle | Dimmer, Number | Number Item = current angle of vertical slats (-90 to +90) . Dimmer Item = the percentage of openness (0%-100%) | ||||
| Name | String | Name of the windows covering | ||||
| TargetHorizontalTiltAngle | Dimmer, Number | Number Item = target angle of horizontal slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%) | ||||
| TargetVerticalTiltAngle | Dimmer, Number | Number Item = target angle of vertical slats. Dimmer Item = the percentage of openness (0%-100%) |
Number temperature_sensor "Temperature Sensor [%.1f °C]" {homekit="TemperatureSensor" [minValue=10.5, maxValue=27] }
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit="Thermostat.CurrentTemperature" [minValue=0, maxValue=40]}
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit="Thermostat.TargetTemperature" [minValue=10.5, maxValue=27]}
Number cooler_current_temp "Cooler Current Temp [%.1f °C]" (gCooler) {homekit="CurrentTemperature"}
Number cooler_cool_thrs "Cooler Cool Threshold Temp [%.1f °C]" (gCooler) {homekit="CoolingThresholdTemperature" [minValue=10.5, maxValue=50]}
Number cooler_heat_thrs "Cooler Heat Threshold Temp [%.1f °C]" (gCooler) {homekit="HeatingThresholdTemperature" [minValue=0.5, maxValue=20]}
# Multiple Instances
HomeKit has a limitation of 150 accessories per bridge.
The bridge itself counts as an accessory, so in practice it's 149.
In order to overcome this limitation, you can instruct openHAB to expose multiple bridges to HomeKit, and then manually assign specific accessories to different instances.
You will need to manually add each additional bridge in the Home app, since the QR Code in settings will only be for the primary bridge; however the same PIN is still used.
In order to assign a particular accessory to a different bridge, set the instance metadata parameter:
Switch kitchen_light {homekit="Lighting" [instance=2]}
Note that instances are numbered starting at 1. If you reference an instance that doesn't exist, then that accessory won't be exposed on any bridge.
For complex items, only the root group needs to be tagged for the specific instance:
Group gSecuritySystem "Security System Group" {homekit="SecuritySystem" [instance=2]}
# Additional Notes
# Console commands
# openHAB is not listed in Home app
if you don't see openHAB in the Home app, probably multicast DNS (mDNS) traffic is not routed correctly from openHAB to Home app device or openHAB is already in paired state. You can verify this with Discovery DNS iOS app (opens new window) as follow:
- start discovery app
- find
_hap._tcpin the list of service types - if you don't find _hap._tcp on the list, probably the traffic is blocked.
networkInterfacesettings - verify the flag "sf".
openhab:homekit clearPairingscommand in karaf console.
- if you see openHAB bridge and sf is equal to 1 but you dont see openHAB in the Home app, the Home app probably still thinks it is already paired with openHAB. remove your home from the Home app and restart the iOS device.
# Re-adding the openHAB HomeKit bridge reports that a bridge is already added, even though it has clearly been removed.
There are various reasons this may happen. Try the following:
- In openhab-cli (opens new window), run
openhab:homekit clearPairings. Try again. - In the HomeKit settings, change the port, setupId, and pin. Save the settings, then re-open the settings so as to refresh the QR code. Re-add the device.
- Remove HomeKit state in
${OPENHAB_USERDATA}/jsondb/homekit.json, and HomeKit config in${OPENHAB_USERDATA}/config/org/openhab/homekit.config. Restart openHAB. Reboot iPhone. Try again.
# A stale HomeKit accessory will not go away after deleting the related item.
You probably have useDummyAccessories enabled in the openHAB HomeKit settings.
See the Dummy Accessories section in the help, above.
# I added an accessory as the wrong type in Home, and updating the item configuration does not cause the change to reflect in the Home app
HomeKit remembers certain configurations about an accessory, from its name to its fundamental type (i.e. fan, light or switch?). If you added it incorrectly, simply updating the item type will not cause Home to update the type. To resolve:
If using text configuration: Comment out the HomeKit metadata for an accessory. If in the GUI, delete the HomeKit metadata for all items associated with the accessory.
If you have
useDummyAccessoriesenabled, open the openhab-cli (opens new window). Runopenhab:homekit listDummyAccessoriesand confirm your item is in the list. Once you've confirmed, clear it withopenhab:homekit clearDummyAccessories.Kill your Home app on your iOS device. Re-open it, and confirm that the accessory is gone.
Uncomment the HomeKit metadata or re-add it via the UI.
You should now see the updated configuration for your accessory.
← ZWave Metrics service →
