# Preface
# openHAB Configuration Files
- via mounting the files shares from the server to your client-PC.
In the main UI as an admin you can go to Help & About and will have the different folder locations under Technical information.
- the exact configuration of the shares can be found on your server at /etc/samba/smb.conf (opens new window).
- Use the share openHAB-conf when mounting it from Windows or macOS
- Find you openHAB-Server via the network share functionality
- User the share openHAB-conf to assign it to a network drive
Finder -> Go -> Connect to Server
- Enter the username and server name to connect to the openHAB Server
- then choose the folder you want to mount
Finding it on Linux
- Access the folder directly on the openHAB server at /etc/openhab
- html
- icons
- items
- services
- html
- persistence
- rules
- scripts
- sitemaps
- sounds
- things
- transform
Also view Creating a Blockly Rule (opens new window)
- go to Settings -> Rules
- press
on bottom right
- enter a unique id and rule name for your new blockly rule
- Under "When" click on "Add Trigger" to define a trigger for the rule (you may add multiple triggers which are perceived as any of those triggers may occurs which stands for an OR combination of the triggers)
- choose a title for the rule
- choose "item" (or something else) that should trigger the rule
- select the item from your model and the click PICK on the upper right corner
- choose "received a command", "was updated" or "changed"
- Under "Then" click on "Add Action"
- choose
- click on
und you should now see this screen
- you can now click the
to access all openHAB Blocks.
- Drag and Drop the blocks to the white area
- Press
Ctrl-s
(Windows) orCommand-s
(macOS) to save your rule - Press
Ctrl-r
(Windows) orCommand-r
(macOS) to directly run your rule with the trigger - Press
Ctrl-d
(Windows) orCommand-d
(macOS) to disable / enable your rule. See the following video onHow to disable Rules (opens new window)
- Click on
on the lower right of the bottom toolbar to see the generated code and will transition to
(click again to come back to the blocks).
More about the topic of code generation can be viewed at Blockly as an ECMA-Script code generator (opens new window)
# Panning and Zooming
You can move around Blockly's workspace by clicking and dragging on the empty space, or by using two fingers on a touch screen or a trackpad.
Zooming can be done using either of these methods:
By pinching or stretching on a touch screen or a trackpad.
By holding Ctrl while dragging or moving with two fingers on the touch screen or trackpad.
With the on-screen controls:
# Context Menu
A context menu is available when right-clicking on a block.
Right-clicking on an empty area in the workspace will pop up a slightly different context menu.
In particular, Clean up Blocks
will automatically move and arrange your blocks neatly.
# Selecting Blocks
Click on a block to select it.
You can select multiple blocks by holding the Shift key while clicking on other blocks. Alternatively, hold down the Shift key, click on an empty area and start dragging to select the blocks within the selection rectangle.
Child blocks are automatically selected when their parent is selected.
Once selected, the blocks can be copied, duplicated, deleted, or moved around.
# Copying & Pasting
Copy-pasting can be used as a quick way to duplicate a set of blocks within the same script. You can also copy a set of blocks into your clipboard, and paste them into another script.
# Other Operations
Duplicate: Clones the block
Add comment: Adds a comment to the block
Inline Inputs / External inputs: Switches between horizontal or vertical alignment of inputs
Inline:
External:
Collapse (expand) block: Shrinks the block to get a better overview
Normal block view:
Collapsed view:
Disable (enable) block: Disables the block, so no code is generated and its functionality switched off
Delete: delete the blocks (this can be reverted via Command/Ctrl-Z)
# Searching the workspace
Sometimes blockly rules become pretty big, and it is hard to find particular blocks in the rule. Therefore, a search functionality has been provided by pressing Cmd/Ctrl-F which opens a small search window in the top right (just below the "save"-label). After pressing Enter all found blocks that contain the search term are marked in black.
- To be able to conveniently view your log files it is recommended to setup frontail which can be achieved easily via openhabian-config (opens new window)
- Start
openhabian-config
on your server and choose option 20 and then option 21 - After installation you can view your logs under openhabian-config (opens new window) (adapt the server name)
- see how to log (opens new window)
More on that topic can be viewed at Logging (opens new window)
In the developer section there is the possibility to add a sidebar to the blockly rules development workspace that allows to watch live status of an item.
View the chapter Debugging Rules with openHAB Developer Tools to watch Item-Status (opens new window) for more information
