# Multimedia
# Volume
The framework supports some base functions (opens new window) to control the audio sinks' volume.
You can set and get the volume in DSL rules by using these functions:
setMasterVolume(float volume): Sets the volume of the host machine (volume in range 0-1)setMasterVolume(PercentType percent): Sets the volume of the host machineincreaseMasterVolume(float percent): Increases the volume by the given percentdecreaseMasterVolume(float percent): Decreases the volume by the given percentfloat getMasterVolume(): Returns the current volume as a float between 0 and 1
Please refer to the documentation of the Automation add-ons on how to use these actions from the respective language, e.g. JavaScript or JRuby.
# Audio Capture
openHAB is able to capture audio.
There are different options for input devices (so called audio sources):
The distribution comes with these options built-in:
| Output Device | Audio Source | Description |
javasound | System Microphone | This uses the Java Sound API for audio capture. |
Additionally, certain bindings register their supported devices as audio sources, e.g. PulseAudio.
# Console commands
To check which audio sources are available, you can use the console:
openhab> openhab:audio sources
* System Microphone (javasound)
You can define the default audio source either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI in Settings->Audio.
You can also record wav audio files using the console, you should provide the desired record duration in seconds and its filename, if you do not specify the source the default will be used:
openhab> openhab:audio record javasound 10 hello.wav
The generated record will be saved at the folder $OPENHAB_CONF/sounds.
# Audio Playback
openHAB is able to play sound either from the file system (files need to be put in the folder $OPENHAB_CONF/sounds), from URLs (e.g. Internet radio streams) or generated by text-to-speech engines (which are available as optional Voice add-ons).
There are different options for output devices (so called audio sinks):
| Output Device | Audio Sink | Description |
enhancedjavasound | System Speaker (with mp3 support) | This uses the JRE sound drivers plus an additional 3rd party library, which adds support for mp3 files. |
webaudio | Web Audio | Convenient, if sounds should not be played on the server, but on the client: This sink sends the audio stream through HTTP to web clients, which then cause it to be played back by the browser. Obviously, the browser needs to be opened and have a compatible openHAB UI running. Currently, this feature is supported by Main UI, Basic UI and HABPanel. |
Please refer to the Main UI docs for setting up web audio in Main UI.
Additionally, certain bindings register their supported devices as audio sinks, e.g. Sonos speakers.
# Default Audio Sink
You can configure a default audio sink, which will be used if no audio sink is provided in audio and voice actions.
You can define the default audio sink either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI by visitting the Settings page and opening System Settings -> Audio.
# Console commands
To check which audio sinks are available, you can use the console:
openhab> openhab:audio sinks
* System Speaker (enhancedjavasound)
Web Audio (webaudio)
In order to play a sound, you can use the following commands on the console:
openhab> openhab:audio play doorbell.mp3
openhab> openhab:audio play sonos:PLAY5:kitchen doorbell.mp3
openhab> openhab:audio play sonos:PLAY5:kitchen doorbell.mp3 25
openhab> openhab:audio stream example.com
openhab> openhab:audio stream sonos:PLAY5:kitchen example.com
You can optionally specify the audio sink between the play parameter and the file name and between the stream parameter and the URL.
This parameter can even be a pattern including * and ? placeholders; in this case, the sound is played to all audio sinks matching the pattern.
If this parameter is not provided, the sound is played to the default audio sink.
The command to play a file accepts an optional last parameter to specify the volume of playback.
Alternatively the playSound() (opens new window) or playStream() (opens new window) functions can be used in DSL rules:
playSound(String filename): plays a sound from the sounds folder to the default sinkplaySound(String filename, PercentType volume): plays a sound with the given volume from the sounds folder to the default sinkplaySound(String sink, String filename): plays a sound from the sounds folder to the given sink(s)playSound(String sink, String filename, PercentType volume): plays a sound with the given volume from the sounds folder to the given sink(s)playStream(String url): plays an audio stream from an url to the default sink (set url tonullif streaming should be stopped)playStream(String sink, String url): plays an audio stream from an url to the given sink(s) (set url tonullif streaming should be stopped)
If no audio sink is provided, the default audio sink will be used.
UI-based rules support audio actions as well. Just create or edit a rule, add a new action, select "Audio & Voice" and the UI will then guide you trough the setup:
Visit the Blockly docs to learn how to use audio actions from Blockly.
playSound("doorbell.mp3")
playSound("doorbell.mp3", new PercentType(25))
playSound("sonos:PLAY5:kitchen", "doorbell.mp3")
playSound("sonos:PLAY5:kitchen", "doorbell.mp3", new PercentType(25))
playStream("example.com")
playStream("sonos:PLAY5:kitchen", "example.com")
You will find more examples in the documentation of the Automation add-ons and the Blockly docs.
# Voice
# Text-to-Speech
In order to use text-to-speech, you need to install at least one TTS service.
# Default TTS Service & Voice
You can define a default TTS service and a default voice to use either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI by visitting the Settings page and opening System Settings -> Voice.
# Console Commands
To check which Text-to-Speech services are available, you can use the console:
openhab> openhab:voice ttsservices
* VoiceRSS (voicerss)
Once you have installed at least one text-to-speech service, you will find voices available in your system:
openhab> openhab:voice voices
VoiceRSS - allemand (Allemagne) - Hanna (voicerss:deDE_Hanna)
VoiceRSS - allemand (Allemagne) - Jonas (voicerss:deDE_Jonas)
VoiceRSS - allemand (Allemagne) - Lina (voicerss:deDE_Lina)
VoiceRSS - allemand (Allemagne) - default (voicerss:deDE)
VoiceRSS - allemand (Autriche) - Lukas (voicerss:deAT_Lukas)
VoiceRSS - allemand (Autriche) - default (voicerss:deAT)
VoiceRSS - allemand (Suisse) - Tim (voicerss:deCH_Tim)
VoiceRSS - allemand (Suisse) - default (voicerss:deCH)
VoiceRSS - français (France) - Axel (voicerss:frFR_Axel)
VoiceRSS - français (France) - Bette (voicerss:frFR_Bette)
VoiceRSS - français (France) - Iva (voicerss:frFR_Iva)
* VoiceRSS - français (France) - Zola (voicerss:frFR_Zola)
VoiceRSS - français (France) - default (voicerss:frFR)
VoiceRSS - vietnamien (Vietnam) - Chi (voicerss:viVN_Chi)
VoiceRSS - vietnamien (Vietnam) - default (voicerss:viVN)
In order to say a text, you can enter such a command on the console (The default voice and default audio sink will be used):
openhab> openhab:voice say Hello world!
Alternatively you can execute such commands within DSL rules by using the say() (opens new window) function:
say(Object text): says a given text with the default voicesay(Object text, PercentType volume): says a given text with the default voice and the given volumesay(Object text, String voice): says a given text with a given voicesay(Object text, String voice, PercentType volume): says a given text with a given voice and the given volumesay(Object text, String voice, String sink): says a given text with a given voice through the given sinksay(Object text, String voice, String sink, PercentType volume): says a given text with a given voice and the given volume through the given sink
You can select a particular voice (second parameter) and a particular audio sink (third parameter). If no voice or no audio sink is provided, the default voice and default audio sink will be used.
UI-based rules support voice actions as well. Just create or edit a rule, add a new action, select "Audio & Voice" and the UI will then guide you trough the setup. The presented dialog will look similar to the one shown above.
Visit the Blockly docs to learn how to use voice actions from Blockly.
say("Hello world!")
say("Hello world!", new PercentType(25))
say("Hello world!", "voicerss:enGB")
say("Hello world!", "voicerss:enGB", new PercentType(25))
say("Hello world!", "voicerss:enUS", "sonos:PLAY5:kitchen")
say("Hello world!", "voicerss:enUS", "sonos:PLAY5:kitchen", new PercentType(25))
# Speech-to-Text
In order to use Speech-to-Text, you need to install at least one STT service.
# Console Commands
To check which Speech-to-Text services are available, you can use the console:
openhab> openhab:voice sttservices
* Vosk (voskstt)
You can define a default STT service to use either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI in Settings->Voice.
# Keyword Spotter
Spotting a keyword is usually the first step to trigger a dialogue with a voice assistant. In order to spot keyword, you need to install at least one Keyword Spotter service.
# Console Commands
To check which Keyword Spotter services are available, you can use the console:
openhab> openhab:voice keywordspotters
* Porcupine (porcupineks)
You can define a default Keyword Spotter service to use either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI in Settings->Voice.
# Human Language Interpreter
Human language interpreters are meant to process prose that e.g. is a result of voice recognition or from other sources.
There are two implementations available by default:
| Interpreter | Type | Description |
rulehli | Rule-based Interpreter | This mimics the behavior of the Android app - it sends the string as a command to a (configurable, default is "VoiceCommand") item and expects a rule to pick it up and further process it. |
system | Built-in Interpreter | This is a simple implementation that understands basic home automation commands like "turn on the light" or "stop the music". Explained in more detail below. |
opennlp | HABot OpenNLP Interpreter | A machine-learning natural language processor based on Apache OpenNLP for intent classification and entity extraction. |
# Console Commands
To check which human language interpreters are available, you can use the console:
openhab> openhab:voice interpreters
Built-in Interpreter (system)
* Rule-based Interpreter (rulehli)
You can define a default human language interpreter to use either by textual configuration in $OPENHAB_CONF/services/runtime.cfg or in the UI in Settings->Voice.
To test the interpreter, you can enter such a command on the console (assuming you have an Item with label 'light'):
openhab> openhab:voice interpret turn on the light
The default human language interpreter will be used. In case of interpretation error, the error message will be said using the default voice and default audio sink.
Alternatively you can execute such commands within DSL rules using the interpret() (opens new window) function:
interpret(Object text): interprets a given text by the default human language interpreterinterpret(Object text, String interpreters): interprets given text by given human language interpreter(s)interpret(Object text, String interpreters, String sink): interprets a given text by given human language interpreter(s) and using the given sink
You can select particular human language interpreter(s) (second parameter) and a particular audio sink (third parameter). If no human language interpreter or no audio sink is provided, the default human language interpreter and default audio sink will be used.
The human language interpreter(s) parameter must be the ID of an installed interpreter or a comma separated list of interpreter IDs; each provided interpreter is executed in the provided order until one is able to interpret the command.
The audio sink parameter is used when the interpretation fails; in this case, the error message is said using the default voice and the provided audio sink. If the provided audio sink is set to null, the error message will not be said.
The interpretation result is returned as a string. Note that this result is always a null string with the rule-based Interpreter (rulehli).
interpret("turn on the light")
var String result = interpret("turn on the light", "system")
result = interpret("turn on the light", "system", null)
result = interpret("turn on the light", "system,rulehli")
result = interpret(VoiceCommand.state, "system", "sonos:PLAY5:kitchen")
# Voice Assistant
openHAB embeds a dialog processor based on the services previously presented on this page. With this dialog processor and these services, openHAB can become a voice assistant dedicated to home automation. Here are the components needed to instantiate a voice assistant:
- an audio source: the audio device that will listen for user speaking,
- a keyword spotter: this will detect the keyword defined by the user to start a dialogue,
- a Speech-to-Text service: captured audio will be converted into text,
- one (or more) interpreter(s): the text will be analyzed and converted into commands in the automation system and a response will be produced,
- a Text-to-Speech service: the text response will be converted into an audio file,
- an audio sink: the audio file will be played to be heard by the user.
The quality of the voice assistant will of course depend on the quality of each of the selected components.
Your openHAB server can run multiple voice assistants but can only run one voice assistant for a given audio source.
After you start a voice assistant, it will live until you stop it, which means it will continue to detect keyword and handle dialogues.
However, there is a special mode that allows handling a single dialogue, bypassing keyword detection and starting to listen for user request immediately after running it.
You do not need to stop it, it stops automatically after handling the user request.
It's something you could run in a rule triggered by a particular user action, for example.
This mode is executed using the listenAndAnswercommand.
# Console Commands
To start and stop a voice assistant, you can enter such commands on the console:
# start a dialog
openhab> openhab:voice startdialog --source javasound --sink sonos:PLAY5:kitchen --hlis system,rulehli --stt voicerss --tts voskstt --keyword terminator --ks rustpotterks
# list running dialogs
openhab> openhab:voice dialogs
# register a dialog (same as start but persisting the configuration to spawn dialog on restart or temporal service unavailability).
openhab> openhab:voice registerdialog --source javasound --sink sonos:PLAY5:kitchen --hlis system,rulehli --tts voicerss --stt voskstt --keyword terminator --ks rustpotterks
# list dialogs registrations
openhab> openhab:voice dialogregs
# stop a dialog
openhab> openhab:voice stopdialog --source javasound
# unregister a dialog, and stop if running
openhab> openhab:voice unregisterdialog --source javasound
# run single shot dialog
openhab> openhab:voice listenandanswer --source javasound --sink sonos:PLAY5:kitchen --hlis system,rulehli --tts voicerss --stt voskstt --keyword terminator --ks rustpotterks
# run transcription and output to the console
openhab> openhab:voice transcribe --source javasound --stt voskstt
When an argument is not provided in the command line, the default from the voice settings is used. If no default value is set in voice settings, the command will fail.
You can select particular human language interpreter(s). This parameter must be the ID of an installed interpreter or a comma separated list of interpreter IDs; each provided interpreter is executed in the provided order until one is able to interpret the command.
If the language is defined in the regional settings, it is used as the language for the voice assistant; if not set, the system default locale is assumed. To not fail, the keyword spotter, the Speech-to-Text and Text-to-Speech services, and the interpreters must support this language.
You can select a particular voice for the Text-to-Speech service. If no voice is provided, the voice defined in the regional settings is preferred. If this voice is not associated with the selected Text-to-Speech service or not applicable to the language used, any voice from the selected Text-to-Speech service applicable to the language being used will be selected.
Using the 'Listening Melody' in the voice settings, you can configure an acoustic melody to be played when the keyword is spotted before the voice command recognition stars.
Other interesting options for the dialog initialization are:
- --dialog-group
<group name>: You can prevent simultaneous execution of dialogs by assigning them to same group, by default they are assigned the 'default' group. - --location-item
<ItemName>: You can provide an Item as location context for the dialogs, the interpreters can take advantage of these. - --listening-item
<ItemName>: You can configure an Item to be "ON"/"OFF" on recognition start/stop, useful for example to trigger a rule that mutes the surrounding devices.
Alternatively you can execute such commands within DSL rules using the startDialog() (opens new window), stopDialog() (opens new window) and listenAndAnswer() (opens new window) functions:
startDialog(String source, String sink): starts dialog processing for a given audio sourcestartDialog(String ks, String stt, String tts, String voice, String interpreters, String source, String sink, String locale, String keyword, String listeningItem): starts dialog processing for a given audio sourcestopDialog(String source): stops dialog processing for a given audio sourcelistenAndAnswer(String source, String sink): executes a simple dialog sequence without keyword spotting for a given audio sourcelistenAndAnswer(String stt, String tts, String voice, String interpreters, String source, String sink, String locale, String listeningItem): executes a simple dialog sequence without keyword spotting for a given audio source
Each parameter can be null; in this case, the default from the voice settings is used.
If no default value is set in the voice settings, the action will fail.
The interpreters parameter for startDialog and listenAndAnswer must be the ID of an installed interpreter or a comma separated list of interpreter IDs; each provided interpreter is executed in the provided order until one is able to interpret the command.
The locale parameter for startDialog and listenAndAnswer is the language to be used by the voice assistant.
If null is provided, the language defined in the regional settings is used; if not set, the system default locale is assumed.
The voice parameter for startDialog and listenAndAnswer is the voice to be used by the Text-to-Speech service.
If null is provided, the voice defined in the regional settings is preferred.
The listeningItem parameter for startDialog and listenAndAnswer is the Item name of the listening switch.
This Item is switched on during the period when the dialog processor has spotted the keyword and is listening for commands.
If null is provided, the default Item from the voice settings is used.
If not set, no Item will be switched on and off.
startDialog(null, null)
stopDialog(null)
startDialog("javasound", "sonos:PLAY5:kitchen")
stopDialog("javasound")
startDialog("porcupineks", "voskstt", "voicerss", "voicerss:frFR_Zola", "system,rulehli", "javasound", "sonos:PLAY5:kitchen", "fr-FR", "terminator", "listeningItem")
listenAndAnswer(null, null)
listenAndAnswer("javasound", "sonos:PLAY5:kitchen")
listenAndAnswer("voskstt", "voicerss", "voicerss:frFR_Axel", "system,rulehli", "javasound", "sonos:PLAY5:kitchen", "fr-FR", "listeningItem")
# The Built-in Interpreter
The interpreter is available by default and includes built-in grammar for English, German, French and Spanish that can be extended using the voiceSystem metadata. Here are some examples of the built-in English grammar:
increase the <item name>
decrease the <item name>
set the color of the <item name> to red
put the <item name> to next
put the <item name> to previous
play the <item name>
pause the <item name>
rewind the <item name>
fast forward the <item name>
start the <item name>
stop the <item name>
refresh the <item name>
For exact built-in grammar you can refer to the source code (opens new window).
# Target Item
The interpreter resolves the Item name based on its label/synonyms and its parent label/synonyms.
An example of the possible situations could be:
If you have Group Item labeled as TV with a Dimmer child Brightness:
The interpreter understands these phrases as the same turn off tv, turn off brightness, turn off tv brightness and turn off brightness tv.
If you add a Switch child labeled as Power to the group:
The interpreter now also understands the phrases turn off power, turn off tv power and turn off power tv.
But the turn off tv phrase now detects a collision because of two matching Items accepting the OFF command.
# Name prevalence
One way you can solve this is by using the name prevalence, Items with start with other Items names take prevalence over them.
If the Switch Item has the name tv and the Dimmer Item the name tv_brightness there will be no collisions between them and therefore the OFF command will target the Switch Item.
# Exact match label/synonym prevalence
Another way you can solve this is by using the exact match prevalence, Items whose label/synonym match the one in the command exactly take prevalence.
If the Switch Item has the synonym TV there will be no collisions between them and therefore the OFF command will target the Switch Item.
# Location prevalence
The dialog processor forwards its configured location Item to the standard interpreter to be used for reducing collisions on the target resolution.
If you have two Items labeled as Light but one is a child of the location Item that has been configured for the dialog execution, the Item takes prevalence.
So the phrase Turn on the light will work correctly and turn on the Item at your location.
The location takes prevalence over an exact match.
# Item description rules
The interpreter also creates rules for your Item descriptions for English, German, French, Italian and Spanish.
If you have a Dimmer Item called Light with command description 100=high the interpreter will also understand the phrase Set light to high.
# Item custom rules.
You can register custom rules into the interpreter using Items and the metadata namespace voiceSystem.
The examples of valid rules:
"start? watch|watching $*$ on $name$" -> Matches "start watching some show on tv" and sends command "some show".
"watch|play $*$ on tv" -> Matches "play some show on tv" and sends command "some show".
"watch|play $cmd$" -> Matches "play some show" and sends command "some_show_id", only if the Item metadata `commandDescription` contains `some_show_id=some show`.
"start? watch|watching $cmd$ at|on? $name$" -> Matches "watch some show tv" and sends command "some_show_id", only if Item `commandDescription` contains `some_show_id=some show`.
As you can see there are some reserved tokens and characters:
$name$defines the place of the Item name (resolved as explained before), is optional.$cmd$defines the place of a command label, extracted from the Item command description.$*$defines the place of a command, its value is not constrained.|defines alternative word tokens.?defines optional word tokens.
The Item metadata namespace voiceSystem allows following configurations:
- isTemplate: The rule defined on this Item metadata will not target itself but similar Items (Items with same tags and semantic).
- isSilent: The interpreter will say nothing in case these rule is executed correctly (a possible use case can be a trigger for a rule on an Item command to answer programmatically)
- isForced: Send the command without checking the current Item state (default behavior).
Note that if the isTemplate config is false, the rule target is limited to the Item that registers it. When it's true the Item registering the rule gets excluded of been a valid target.
Note that when you use the option isTemplate in rules without the $name$ token, collisions are still solved based on the location. So you can have a play $cmd$ here rule which is scoped to the dialog location.
There are some limitations:
- Rule should contain
$cmd$or$*$but not both. - Rules that include
$name$and$*$should have at least one non-optional token between them. - Rules must not start by
$name$or$*$, neither by them prefixed only of optional tokens. - Rules must not contain
$name$,$cmd$or$*$multiple times.
