# Modbus Sungrow Binding
This binding integrates the sungrow inverters into openHAB. It is based on the Sungrow specification "Communication Protocol of Residential Hybrid Inverter V1.0.23", which can be found here: https://github.com/bohdan-s/SunGather/issues/36 (opens new window).
# Supported Inverters
As defined within the spec mentioned above the following inverters are supported, but not all are tested yet:
  • SH3K6
  • SH4K6
  • SH5K-20
  • SH5K-V13
  • SH3K6-30
  • SH4K6-30
  • SH5K-30
  • SH3.0RS
  • SH3.6RS
  • SH4.0RS
  • SH5.0RS
  • SH6.0RS
  • SH5.0RT
  • SH6.0RT
  • SH8.0RT
  • SH10RT
The binding supports only one thing:
  • sungrow-inverter: The sungrow inverter
# Preparation
The data from the inverter is read via Modbus. So you need to configure a Modbus Serial Slave serial or Modbus TCP Slave tcp as bridge first. If you are using a Modbus TCP Slave and the WiNet-S Communication Module please ensure:
  • that you have the correct IP-Address of your WiNet-S Device
  • that Modbus is enabled within the Communication Module
  • that you've the correct port number
  • that the white list is disabled or your openHAB instance IP is listed
Enabling modbus and whitelist setting can be done in WiNet-S Web-UI as shown below: WiNet-S Modbus configuration
Once you've configured the Modbus TCP Slave or Modbus Serial Slave as Bridge you can configure the Sungrow inverter thing. You just have to select the configured bridge and optional configure the polling interval.
# Sungrow Inverter (sungrow-inverter)
Name Type Description Default Required Advanced
pollInterval integer Interval the device is polled in ms. 5000 yes no
The sungrow-inverter thing has channels that serve the current state of the sungrow inverter, as you are used to from the iSolareCloud Website and App.
Channel Type ID Item Type Description Advanced Channel Group
sg-internal-temperature Number:Temperature Internal Temperature yes Overview
sg-total-dc-power Number:Power Total DC Power no Overview
sg-phase-a-voltage Number:ElectricPotential Phase A Voltage yes Overview
sg-phase-b-voltage Number:ElectricPotential Phase B Voltage yes Overview
sg-phase-c-voltage Number:ElectricPotential Phase C Voltage yes Overview
sg-daily-pv-generation Number:Energy Daily PV Generation no Overview
sg-total-pv-generation Number:Energy Total PV Generation no Overview
sg-reactive-power Number:Power Reactive Power yes Overview
sg-power-factor Number:Dimensionless Power Factor yes Overview
sg-phase-a-current Number:ElectricCurrent Phase A Current yes Overview
sg-phase-b-current Number:ElectricCurrent Phase B Current yes Overview
sg-phase-c-current Number:ElectricCurrent Phase C Current yes Overview
sg-total-active-power Number:Power Total Active Power no Overview
sg-grid-frequency Number:Frequency Grid Frequency yes Overview
sg-mppt1-voltage Number:ElectricPotential MPPT1 Voltage yes MPPT Information
sg-mppt1-current Number:ElectricCurrent MPPT1 Current yes MPPT Information
sg-mppt2-voltage Number:ElectricPotential MPPT2 Voltage yes MPPT Information
sg-mppt2-current Number:ElectricCurrent MPPT2 Current yes MPPT Information
sg-daily-battery-charge Number:Energy Daily Battery Charge no Battery Information
sg-total-battery-charge Number:Energy Total Battery Charge no Battery Information
sg-battery-voltage Number:ElectricPotential Battery Voltage yes Battery Information
sg-battery-current Number:ElectricCurrent Battery Current yes Battery Information
sg-battery-power Number:Power Battery Power no Battery Information
sg-battery-level Number:Dimensionless Battery Level no Battery Information
sg-battery-healthy Number:Dimensionless Battery Healthy no Battery Information
sg-battery-temperature Number:Temperature Battery Temperature no Battery Information
sg-daily-battery-discharge-energy Number:Energy Daily Battery Discharge Energy no Battery Information
sg-total-battery-discharge-energy Number:Energy Total Battery Discharge Energy no Battery Information
sg-battery-capacity Number:Energy Battery Capacity no Battery Information
sg-daily-charge-energy Number:Energy Daily Charge Energy no Battery Information
sg-total-charge-energy Number:Energy Total Charge Energy no Battery Information
sg-daily-import-energy Number:Energy Daily Import Energy no Grid Information
sg-total-import-energy Number:Energy Total Import Energy no Grid Information
sg-daily-export-energy Number:Energy Daily Export Energy no Grid Information
sg-total-export-energy Number:Energy Total Export Energy no Grid Information
sg-daily-export-power-from-pv Number:Power Daily Export Power from PV no Grid Information
sg-total-export-energy-from-pv Number:Energy Total Export Energy from PV no Grid Information
sg-export-power Number:Power Export Power no Grid Information
sg-load-power Number:Power Load Power no Load Information
sg-daily-direct-energy-consumption Number:Energy Daily Direct Energy Consumption no Load Information
sg-total-direct-energy-consumption Number:Energy Total Direct Energy Consumption no Load Information
sg-self-consumption-today Number:Dimensionless Self Consumption Today no Load Information
This example shows how to configure a sungrow inverter connected via modbus and uses the most common channels.
sungrow.things
Bridge modbus:tcp:sungrowBridge [ host="10.0.0.2", port=502, id=1, enableDiscovery=false ] {
    Thing sungrow-inverter sungrowInverter "Sungrow Inverter" [ pollInterval=5000 ]
sungrow.items
// Groups
Group sungrowInverter "Sungrow Inverter" ["Inverter"]
Group overview "Overview" (sungrowInverter)
Group batteryInformation "Battery information" (sungrowInverter)
Group gridInformation "Grid information" (sungrowInverter)
Group loadInformation "Load information" (sungrowInverter)
// Overview
Number:Power total_active_power "Total Active Power" (overview) ["Measurement", "Power"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-overview#sg-total-active-power"}
Number:Power total_dc_power "Total DC Power" (overview) ["Measurement", "Power"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-overview#sg-total-dc-power"}
Number:Energy daily_pv_generation "Daily PV Generation" (overview) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-overview#sg-daily-pv-generation"}
Number:Energy total_pv_generation "Total PV Generation" (overview) ["Measurement", "Energy"]  {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-overview#sg-total-pv-generation"}
// Battery information
Number:Power battery_power "Battery Power" (batteryInformation) ["Measurement", "Power"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-battery-information#sg-battery-power"}
Number:Dimensionless battery_level "Battery Level" (batteryInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-battery-information#sg-battery-level"}
Number:Energy daily_charge_energy "Daily Battery Charge Energy" (batteryInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-battery-information#sg-daily-charge-energy"}
Number:Energy daily_discharge_energy "Daily Battery Discharge Energy" (batteryInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-battery-information#sg-daily-battery-discharge-energy"}
// Grid information
Number:Power export_power "Export Power" (gridInformation) ["Measurement", "Power"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-grid-information#sg-export-power"}
Number:Energy daily_export_energy "Daily Export Energy" (gridInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-grid-information#sg-daily-export-energy"}
Number:Energy daily_import_energy "Daily Import Energy" (gridInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-grid-information#sg-daily-import-energy"}
// Load information
Number:Power load_power "Load Power" (loadInformation) ["Measurement", "Power"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-load-information#sg-load-power"}
Number:Energy daily_direct_energy_consumption "Daily Direct Energy Consumption" (loadInformation) ["Measurement", "Energy"] {channel="modbus:sungrow-inverter:sungrowBridge:sungrowInverter:sg-load-information#sg-daily-direct-energy-consumption"}
sungrow.sitemap
sitemap sungrow label="Sungrow Binding"
    Frame {
        Text item=total_active_power
        Text item=total_dc_power
        Text item=daily_pv_generation
        Text item=total_pv_generation
        Text item=battery_power
        Text item=battery_level
        Text item=daily_charge_energy
        Text item=daily_discharge_energy
        Text item=export_power
        Text item=daily_export_energy
        Text item=daily_import_energy
        Text item=load_power
        Text item=daily_direct_energy_consumption
