# NeoHub Binding
The binding supports the following types of Thing..
| Thing Type | Description |
| NeoHub | The Heatmiser NeoHub bridge which is used to communicate with NeoStat and NeoPlug devices |
| NeoStat | Heatmiser Neostat Smart Thermostat |
| NeoPlug | Heatmiser NeoPlug Smart Plug |
| NeoContact | Heatmiser Contact Sensor, wireless door or window contact |
| NeoTemperatureSensor | Heatmiser Wireless Air Sensor, wireless temperature sensor |
The binding automatically searches for NeoHub devices, and puts them in the Main UI Inbox. Alternatively you can manually create a (Bridge) Thing for the NeoHub. In either case you need to enter any missing Configuration Parameters (see Thing Configuration for NeoHub below). Once the Configuration Parameters are all valid, then the NeoHub Thing will automatically attempt to connect and sign on to the hub. If the sign on succeeds, the Thing will indicate its status as Online, otherwise it will show an error status.
Once the NeoHub Thing has been created and it has successfully signed on, it will automatically interrogate the HeoHub to discover all the respective Heatmiser device Things that are connected to it. If in the future, you add additional Heatmiser devices to your system, the binding will discover them too.
The NeoHub Thing connects to the hub (bridge) to communicate with any respective connected Heatmiser device Things. It signs on to the hub using the supplied connection parameters, and it polls the hub at regular intervals to read and write the data for each Heatmiser device. The NeoHub supports two Application Programming Interfaces "API" (an older "legacy" one, and a modern one), and this binding can use either of them to communicate with it. Before the binding can communicate with the hub, the following Configuration Parameters must be entered.
| hostName | Host name (IP address) of the NeoHub (example 192.168.1.123) |
| useWebSocket1) | Use secure WebSocket to connect to the NeoHub (example true) |
| apiToken1) | API Access Token for secure connection to hub. Create the token in the Heatmiser mobile App |
| pollingInterval | Time (seconds) between polling requests to the NeoHub (Min=4, Max=60, Default=60) |
| socketTimeout | Time (seconds) to allow for TCP socket connections to the hub to succeed (Min=4, Max=20, Default=5) |
| preferLegacyApi | ADVANCED: Prefer to use older API calls; but if not supported, it switches to new calls (Default=false) |
| portNumber2) | ADVANCED: Port number for connection to the NeoHub (Default=0 (automatic)) |
1) If useWebSocket is false, the binding will connect via an older and less secure TCP connection, in which case apiToken is not required.
However see the chapter "Connection Refused Errors" below.
Whereas if you prefer to connect via more secure WebSocket connections then an API access token apiToken is required.
You can create an API access token in the Heatmiser mobile App (Settings | System | API Access).
2) Normally the port number is chosen automatically (for TCP it is 4242 and for WebSocket it is 4243). But you can override this in special cases if you want to use (say) port forwarding.
# Connection Refused Errors
From early 2022 Heatmiser introduced NeoHub firmware that has the ability to enable / disable connecting to it via a TCP port. If the TCP port is disabled the OpenHAB binding cannot connect and the binding will report a "Connection Refused" warning in the log. In prior firmware versions the TCP port was always enabled. But in the new firmware the TCP port is initially enabled on power up but if no communication occurs for 48 hours it is automatically disabled. Alternatively the Heatmiser mobile app has a setting (Settings | System | API Access | Legacy API Enable | On) whereby the TCP port can be permanently enabled.
The NeoHub Thing connects to the hub (bridge) to communicate with any Heatmiser devices that are connected to it. Each such Heatmiser device is identified by means of a unique device name in the hub. The device name is automatically discovered by the NeoHub Thing, and it is also visible (and changeable) via the Heatmiser App.
| deviceNameInHub | Device name that identifies the Heatmiser device in the NeoHub and the Heatmiser App |
# Channels for "NeoHub"
| meshNetworkQoS | Number:Dimensionless | RF mesh network Quality-of-Service; this is the percentage of configured devices that are currently connected online via the RF mesh network |
| roomTemperature | Number:Temperature | Actual room temperature |
| floorTemperature | Number:Temperature | Actual floor temperature |
| thermostatOutputState | String | Status of whether the thermostat is Off, or calling for Heat |
| occupancyModePresent | Switch | The thermostat is in the Present Occupancy Mode (Off=Absent, On=Present) |
| batteryLowAlarm | Switch | The battery is low (only applies for battery powered thermostats) (Off=Ok, On=Alarm) |
| plugOutputState | Switch | The output state of the plug switch (Off, On) |
| plugAutoMode | Switch | The plug is in Automatic Mode (Off=Manual, On=Automatic) |
| contactState | Contact | The state of the contact |
| batteryLowAlarm | Switch | The battery is low (Off=Ok, On=Alarm) |
| sensorTemperature | Number:Temperature | Actual measured temperature |
Occasionally it is possible that a device might drop out of the mesh.
If a device drops out of the mesh, you can select whether openHAB shall either a) change the Channel value to UNDEF, or b) hold the value that it had prior to the drop out.
The choice of a) or b) is determined by an optional Channel configuration parameter holdOnlineState as follows.
| holdOnlineState | Switch | If the respective device drops out of the RF mesh, the behaviour is as follows: - Off: openHAB changes the Channel's state to UNDEF- On: openHAB holds the Channel's state unchanged The default setting is Off |
The purpose of holdOnlineState is so you can choose to overlook value fluctuations if drop outs occur e.g. to "hold" the values in a temperature graph display.
Note: if a drop out occurs, the Thing will always change its status to OFFLINE (irrespective of the holdOnlineState setting).
# demo.things File
# demo.items File
# demo.sitemap File
Frame label="Thermostat" {
Frame label="Plug" {
Frame label="Contact" {
Frame label="Sensor" {
Text item=Kitchen_Temperature
