# TA C.M.I. Binding
Via a "Schema API Page"
- Read values from output nodes
- Change values for controllable nodes
- Receive data from analog CAN-outputs defined in TAPPS2
- Receive data from digital CAN-outputs defined in TAPPS2
- Send ON/OFF to digital CAN-inputs defined in TAPPS2
- Send numeric values to analog CAN-inputs defined in TAPPS2
# Prerequisites
When adding objects to this page, the schema for the Object's Pre-Text field has to follow the schema <channelName> <channel description>:
# CoE Configuration
# Configure your CMI for CoE
# Supported Bridge and Things
- TA C.M.I. schema API connection - Thing
This thing reflecting one of our 'schema API page' as defined in the prerequisites. This thing doesn't need the bridge. Multiple of these pages on different C.M.I.'s could be defined within an openHAB instance.
- TA C.M.I. CoE Bridge
In order to get the CAN over Ethernet (COE) envionment working a coe-bridge
has to be created.
The bridge itself opens the UDP port 5441 for communication with the C.M.I. devices.
The bridge could be used for multiple C.M.I. devices.
- TA C.M.I. CoE Connection - Thing
This thing reflects a connection to a node behind a specific C.M.I.. This node could be every CAN-Capable device from TA which allows to define a CAN-Input.
Autodiscovering is not supported. We have to define the things manually.
# TA C.M.I. schema API connection
Parameter Label | Parameter ID | Description | Accepted values |
C.M.I. IP Address | host | Host name or IP address of the C.M.I | host name or ip |
Username | username | Username for authentication on the C.M.I. | string with username |
Password | password | Password for authentication on the C.M.I. | string with password |
API Schema ID | schemaId | ID of the schema API page | 1-256 |
Poll Interval | pollInterval | Poll interval (in seconds) how often to poll the API Page | 1-300; default 10 |
This thing doesn't need a bridge. Multiple of these things for different C.M.I.'s could be defined within an openHAB instance.
# TA C.M.I. CoE Connection
Node | node | The CoE / CAN Node number openHAB should represent | 1-64 |
The channels provided by this thing depend on the configuration of the "schema API page". All the channels are dynamically created to match it. Also when the API Page is updated, the channels are also updated during the next refresh.
The channels have a parameter allowing to configure their update behavior:
Update Policy | updatePolicy | Update policy for this channel. Default means "On-Change" for channels that can be modified and "On-Change" for read-only channels. | 0 (Default), 1 (On-Fetch), 2 (On-Change) |
The behavior in detail:
Default
(0
): When the channel is 'read-only' the update-policy defaults to On-Fetch . When the channel is linked to something that can be modified it defaults to On-Change .On-Fetch
(1
): This is the default for read-only values. This means the channel is updated every time the schema page is polled. Ideally for values you want to monitor and log into charts.On-Change
(2
): When channel values can be changed via OH it is better to only update the channel when the value changes. The binding will cache the previous value and only send an update when it changes to the previous known value. This is especially useful if you intend to link other things (like i.e. Zigbee or Shelly switches) to the TA via OH that can be controlled by different sources. This prevents unintended toggles or even toggle-loops.
Some comments on the CoE Connection and channel configuration: As you might already have taken notice when studying the TA's manual, there are always a multiple CoE-values updated within a single CoE-message. This is a design decision made by TA. But this also means for CoE-Messages from openHAB to TA C.M.I. we have to send multiple values at once. But due to OH's design there is no default restore of previous values out of the box. So after OH startup the output thing channels are either initialized with it's configured default value or flagged as 'unknown' until the first update on the channel happens. You could either use some 'illegal' value as initial value and use CoE Value Validation on the TA side to detect invalid values. Another option would be to use only every 4th analog and 16th digital channel if you only need a few channels. Additionally you could use OH's persistence service (opens new window) and it's option to restore the item states (opens new window) during OH startup. As this only restores the item states you have to write a rule issuing postUpdates on the items with the item's current value so the channel for the binding is updated.
Channel | Type | Description |
coe-digital-in | Switch (RO) | Digital input channel for digital state data received from the node |
coe-digital-out | Switch | Digital output channel for digital state data sent to the node |
coe-analog-in | Number (RO) | Analog input channel for numeric values received from the node |
coe-analog-out | Number | Analog output channel for numeric values sent to the node |
Channel's coe-digital-in
and coe-analog-in
Output | output | C.M.I. Network Output | 1-64 |
Channel coe-digital-out
Initial Value | initialValue | Initial value to set after startup (optional, defaults to uninitialized) | true (on) / false (off) |
Channel coe-analog-out
Measurement Type | type | Measurement type for this channel (see table below) | 0-21 |
Initial Value | initialValue | Initial value to set after startup (optional, defaults to uninitialized) | floating point numeric |
id | type | unit | description |
1 | Temperature | °C | Temperature value, multiplied by 0.1 |
2 | Energy Flux | W/m2 | e.g. for solar irridiation |
3 | Flow Rate | l/h | e.g. for flow meters such as TA FTS-xx |
4 | Time | s | |
5 | Time | min | |
6 | Flow Rate | l/lmp | standardized lpm flowrate |
7 | Temperature | K | Kelvin, e.g. for Temperature differences |
8 | Percentage | % | |
9 | unknown | : | might be another dimensionless unit |
10 | Power | kW | |
11 | Energy | KWh | |
12 | Energy | MWh | |
13 | el Voltage | V | |
14 | el. Current | mA | |
15 | Time | hours | |
16 | dimensionless | [none] | use for multiplexers, etc |
17.. | repeating again from 1, e.g 17==1, 18==2, ... |
Example of a .thing file:
Sample .items-File:
# APIPage-items
# COE-items
Number TACMI_Analog_In_1 "TA input value 1 [%.1f]" <temperature> {channel="tacmi:cmi:coe-bridge:cmiTest:analogInput1"}
Number TACMI_Analog_Out_1 "TA output value 1 [%.1f]" <temperature> {channel="tacmi:cmi:coe-bridge:cmiTest:analogOutput1"}
Switch TACMI_Digital_In_1 "TA input switch 1 [%s]" {channel="tacmi:cmi:coe-bridge:cmiTest:digitalInput1"}
Switch TACMI_Digital_Out_1 "TA output switch 1 [%s]" {channel="tacmi:cmi:coe-bridge:cmiTest:digitalOutput1"}
Sample .sitemap snipplet
Text item=TACMI_Analog_In_1
Some additional hints and comments:
You might already have noticed that some state information is in German.
As I have set the Accept-Language
-Http-Header to en
for all request and found no other way setting a language for the schema pages I assume it is a lack of internationalization in the C.M.I.
You could circumvent this by creating map files to map things properly to your language.
← Systeminfo tado° →
