# Tellstick Binding
  • Dimmable Device - Usually for controlling lamps. dimmer
  • Switchable Device - On/Off only could be lamps or other electronic equipment. switch
  • Sensors - Temperature- and humidity-sensors. sensor
  • Telldus Core Bridge - Oldest API, used by USB devices. telldus-core
  • Telldus Live Bridge - Telldus Cloud service, all devices with online access. telldus-live
  • Telldus Local Bridge - Telldus Local API, Tellstick Net v2/Tellstick ZNet Lite v1/v2. telldus-local
# Switchbased sensors workaround
  • Some 433MHz magnetic & PIR sensors, for example, magnetic door sensors, are detected as regular switch Things instead of type contact. There is technically no way of distinguish them apart from regulur switch Things. For using them as sensors only (not paired to a lamp) please consult the workaround in the channel section.
# Binding Configuration
# Dimmers & switches
There is an option to override the resend count of the commands. Use the option repeat for that. Default resend count is 2.
# Bridges
Depending on your Tellstick device type there is different ways of using this binding. The binding implements three different APIs: 1) Telldus Core which is a local only interface supported by USB based device.
2) Telldus Live which is a REST based cloud service maintained by Telldus. 3) Telldus Local which is a REST based local service maintained by Telldus.
Model Telldus Core Telldus Live Local REST API Verified working with openHAB
Tellstick Basic X X X
Tellstick Duo X X X
Tellstick Net v.1 X X
Tellstick Net v.2 X X
Tellstick ZNet Lite v.1 X X X
Tellstick ZNet Lite v.2 X X
# Telldus Core Bridge
To enable communication between openHAB and tellstick-core service (Telldus center) they must use same architecture, eg. 32-bit or 64-bit. The supplied version from Telldus is compiled against 32-bit architecture. Therefore, it is better to use 32-bit java for openHAB. To check which version of Java is currently in use, run: java -d32 -version
For changing architecture in Linux check out: dpkg --add-architecture
Optional:
  • libraryPath: The path to tellduscore.dll/so semicolon seperated list of folders.
  • resendInterval: The interval between each transmission of command in ms, default 100ms.
# Telldus Live Bridge
To configure Telldus Live you have request OAuth tokens from Telldus. Goto this page https://pa-api.telldus.com/keys/index (opens new window) and request your keys and update the config.
Required:
  • privateKey: Private key
  • publicKey: Public key
  • token: Token
  • tokenSecret: Token secret
Optional:
  • refreshInterval: How often we should contact Telldus Live to check for updates (in ms)
# Telldus Local Bridge
Required:
  • ipAddress: Local IP address of your Tellstick device
  • accessToken: Access Token
Optional:
  • refreshInterval: How often we should contact Telldus Local to check for updates (in ms)
Channel Type ID Item Type Description
dimmer Number This channel indicates the current dim level
state Switch This channel indicates whether a device is turned on or off.
timestamp DateTime This channel reports the last time this device state changed.
humidity Number:Dimensionless This channel reports the current humidity in percentage.
temperature Number:Temperature This channel reports the current temperature.
timestamp DateTime This channel reports the last time this sensor was updates.
watt Number:Power This channel reports the current watt.
ampere Number:ElectricCurrent This channel reports the current ampere.
windgust Number:Speed The current peak wind gust.
winddirection Number:Angle The current wind direction.
windaverage Number:Speed The current wind average.
rainrate Number:Length This current rate of rain.
raintotal Number:Length The total rain.
All switchbased sensors are binary and the goal is to represent them as a contact item in openHAB. Eg. a door is open or closed and can't be altered by sending a radio signal. To achieve that we will create a proxy item which is updated by a rule.
Switch front_door_sensor    "Front door"  <door>  {channel="tellstick:switch:1:7:state"}
Contact front_door_proxy    "Front door"  <door>
rule "proxy_front_door_on"
rule "proxy_front_door_off"
# tellstick.things
# tellstick.items
